1.95 b2: IPTC Field modify problem.
PSHRutPark
Post by PSHRutPark »
If one attempts to modify an IPTC field (ie one currently containing data) the change is not written if the "Update or Create XMP" option is set.
This operation is with the "Overwrite current values" button set and, at least, relates to JPG files (haven't tested others).
(I don't know if this was occurring before the current betas)
Thanks
PETER
Re: B1 and B2 IPTC Field modify problem.
PSHRutPark wrote:If one attempts to modify an IPTC field (ie one currently containing data) the change is not written if the "Update or Create XMP" option is set.
Could you send me a jpg sample to test? And tell me which field do you change? And which options?
PSHRutPark
xnview wrote: Could you send me a jpg sample to test? And tell me which field do you change? And which options?
Sample JPG emailed.
PETER
PSHRutPark
Re: B1 and B2 IPTC Field modify problem. B3 update
Thanks
PETER
With Beta 3 the field is now written if the "Update or Create XMP" option is set. But Xnview crashes immediately and the programme has to be restarted to view results.
PETER
oops66
Post by oops66 »
...With Beta 3 the field is now written if the "Update or Create XMP" option is set. But Xnview crashes immediately and the programme has to be restarted to view results.
Confirmed, I have a crash too (v1.95b3 - "Ctrl+i" ) after adding an IPTC keyword and "write".
When I restart, the IPTC keyword is added into IPTC core but not into the XMP core.
PSHRutPark wrote: With Beta 3 the field is now written if the "Update or Create XMP" option is set. But Xnview crashes immediately and the programme has to be restarted to view results.
With all jpg?
oops66
Post by oops66 »
With all jpg?
Not sure but I think so, I have tried 5 different jpg files.
Ok, a problem in the package, i've updated the zip
oops66
Post by oops66 »
Only fixed in v1.95rc1 for keywords, and some fields, when "create or update XMP" is checked but:
This problem persist for some others fields:
Origin tab:
City
Sublocation
Misc. tab:
Original transmission reference
Date / Time tab:
Date created(YYYYMMDD)
Time Created
http://newsgroup.xnview.com/viewtopic.php?p=67018#67018
oops66
Post by oops66 »
The problem persist into the final release v1.95 only for this field now:
Misc. tab:
see here:
http://newsgroup.xnview.com/viewtopic.php?p=67189#67189
oops66 wrote:The problem persist into the final release v1.95 only for this field now:
Misc. tab:
see here:
Yes, will be fixed
Has this problem been resolved in the 1.95. final?
