"Print to file" in print-dialogue
Peter2
Please add the option "print to file" to print dialogue. This is a standard-feature of nearly all software-products.
Thanks.
Peter
Thanks.
Peter
Peter2
Refresh: "Print to file" in print-dialogue
I want to refresh this topic for further development.
Peter
Peter
Peter2
Re: Refresh: "Print to file" in print-dialogue
Again ..
PeterPeter2 wrote:I want to refresh this topic for further development.
Larry_of_Troy
Re: "Print to file" in print-dialogue
I'll second this. Makes it much easier converting documentation produced in .tif format to something usable [.ps to .pdf for example].
GhostOrchid
work around:
install PDFCreator from sf.net
it's free and allow all application to print to pdf
But why do you want this feature? Print a picture in a file, i don't see any benefitPeter2 wrote:Please add the option "print to file" to print dialogue. This is a standard-feature of nearly all software-products.
- Forum Librarian
AllWeb Software (FastPrint » [url=http://www.allweb-soft.com/fastprint.htm]FAQs[/url]) wrote:Normally this whole process of creating the PRN file is transparent, you print a document in your favourite application and the paper starts feeding through the printer. There can however be some uses for intercepting and capturing a PRN file before it gets to the printer. Having the PRN file allows you to reprint the document without running or even having the original application that created the file, for instance if you run a print shop with a wide format plotter and your customers use AutoCAD to produce plots you can have them send a raw PRN file and output using that without needing AutoCAD.
Corel (Putting It All Together » Image Design » [url=http://apps.corel.com/partners_developers/casb/serviceb/puttogether/idesign/pagelayout.htm#output]Page Layout[/url]) wrote:Some service bureaus accept drawings in .CDR format whereas others will request a .PRN (print file) or a .PDF (Adobe Portable Document Format). The benefit of using a .PRN file is that it is a self-contained file which can be copied to an output device even if CorelDRAW is not installed on the computer to which the device is attached.
- Frogmore Computer Services: What is a PRN file?
- Productivity Portfolio: PRN Files Fill the Gaps
- Queensland Government Web Centre: Creating PDFs
- WebXealot @ Xara Xone: Creating a Printer (PRN) File
- Four Point Printing: Creating a PRN file for Four Point Printing
- Peter Lerup: PrintFile
- Russ Wright: PrnPrint
- Lee Tet Woo: PRNter
- Oleg Kovalenko: NT EMF Spool, PCL5-6, HP-GL/2, ZjStream plugin for XnView
Peter2
Yeah, at the first glance, a print-file is a picture of a picturexnview wrote:...Print a picture in a file, i don't see any benefit
But generally:
- It is a file which is full-defined in colours, resolution, rotation, size, footmarks, borders.
- You don't need a software to handle the files (e.g. XnView for pictures); at least you need a DOS-command to print the files (copy *.prn lpt1) - or one of the useful helpers listed above.
- You can separate the process of file handling: Department A (technics, design) produces print files with specialised software, Department B (repro, copy shop) produces the paper.
- You can separate the schedule of file handling: during the day you produce the print-files, in the evening you start a batch-job which prints hundreds of sheets without jamming the printer of your colleagues.
- You can use different software (graphics, CAD, Office, ...) to produce one single type of output. And PDF is not always the best way of "single type of output".
Regards
Peter
PS: more plot- and print- and pdf-tools on http://www.noliturbare.com/index.php
Oh ok as a PRN file. I'll search how to write in PRN format...
Peter2
Finexnview wrote:Oh ok as a PRN file. ...
xnview wrote:...search how to write in PRN format...
PRN (or PLT) is not a "defined file-format"; it is the stored datastream produced of the different, user-selected printer-drivers. You will get PRN/PLT files with different contents: PS / RPCS / PCL / HPGL - HP-RTL / ...
Peter
So you would like the 'print to file' in windows print dialog?Peter2 wrote:xnview wrote:...search how to write in PRN format...![]()
- Forum Librarian
Workaround:
- Gallicrow Software: Printing FAQ » How can I “Print to file” if the program that I'm using doesn't have that option?
Peter2
Yes - and partially "Not only" ..xnview wrote:So you would like the 'print to file' in windows print dialog?
I wrote about this in some other postings, related to that suggestion.
The "print to file" would be the first and a standard-step - it enables the user to make single print-files. The standard-problem of this standard-feature is the annoying dialogue-box which asks for the file-name.
A next step (and a really useful one) would be a batch-function for print files: the software does not ask for every file-name, it takes the file-name of the picture ("mytest.jpg") and makes a print-file: mytest.prn or mytest_jpg.prn or mytest_jpg.plt.
Peter
- Forum Librarian
Peter2 wrote:I wrote about this in some other postings, related to that suggestion.
Peter2
ExactlyXnTriq wrote:Peter2 wrote:I wrote about this in some other postings, related to that suggestion.Batch-print to plotfile?
Peter
