sfw files
hornshark
sfw files
Post by hornshark »
I am using XnView 1.94.2 with Windows Vista. I have several dozen sfw (Seattle Film Works) files. So far I have been unable to open or convert any of them. All I get is an error message saying that the format is not recognized. Any suggestions?
Re: sfw files
You must enable option/General/Use all formats
hornshark
sfw files
Post by hornshark »
I'm sorry but I can't find that command in any of the directories. I enabled the "Display all image files types" but it still doesn't recognize the file format. Was that the command you were referring to?
Re: sfw files
hornshark wrote:I'm sorry but I can't find that command in any of the directories. I enabled the "Display all image files types" but it still doesn't recognize the file format. Was that the command you were referring to?
Strange, could you send me a sample?
hornshark
sfw files
Post by hornshark »
How do I do that?
Dreamer
Post by Dreamer »
Send the file via email (webmaster at xnview dot com), if possible, if not, you can use http://www.mediafire.com/ for example (free, no registration) to upload the file and send the link to Pierre.
Dreamer
hornshark
sfw files
Post by hornshark »
Sample sfw files emailed to webmaster. Thank you very much for all your help.
Re: sfw files
Your samples are not in Seattle FilmWorks format
hornshark
sfw files
Post by hornshark »
That's very odd because that's were I had them processed back in '97. Can you tell what format they are in and perhaps were I could find a program to open them with or am I SOL?
hornshark
sfw files
Post by hornshark »
Any luck figuring out what format my files are in?
