fixed in v1.95rc1 thumbnails folders become hidden.
oops66
Post by oops66 »
1.95 beta3, Severe bug :
When I launch XnView1.95b3 into the browser mode, all thumbnails related to folders become hidden.
See the picture bellow - Folders 1, 2, 3, 4, 5 are now hidden into this beta3:
Re: 1.95B3 thumbnails folders become hidden.
'other files' in file list is enabled? Which filter do you use?
oops66
Post by oops66 »
xnview wrote:'other files' in file list is enabled? Which filter do you use?
Very good Pierre, you are right, I had for all others files before: 0100 (1 means checked) but that worked fine before the 1.95b3 release...
and now with: 1100 , that works also into the 1.95b3
Thanks for your help !
LOL, and by this way you have solved an old unknown bug
FI: for Filter custom :
1-add) HTM HTML MHT MHTML XML XHTML EML NWS URL MIE
2-remove) "empty"
i can't reproduce this bug, could you send me your .ini
oops66
Post by oops66 »
xnview wrote:i can't reproduce this bug, could you send me your .ini
Not needed, that works now with my new setting above!
But if you use previous settings, there a problem, i think!
oops66
Post by oops66 »
Yes,
I send you my .ini in case of, by e-mail.
Do you can reproduce this now ???
oops66 wrote:Do you can reproduce this now ???
Yes, will be fixed
oops66
Post by oops66 »
Yes, will be fixed
Fixed in v1.95rc1
