Can't delete empty folders with DEL key
otreus
i think it is a bug
ckv
Could you be little more specific?
Del ?
• I assume you mean the DEL key ?
- If so, I confirm that one can't delete any folder (empty or not) with that key in the Browser,
neither from the tree nor from the thumb nails board.
- The only way is to use the right-click menu either in the tree (you'll get a prompt from Win to confirm),
or from the thumb nails panel (no prompt) whether the whole branch is displayed.
- In the two cases, the folder is sent to the Recycle Bin.
- When you have only the empty folder in the board, there is not any right-click menu…
otreus
don't know why u can't reproduce it but i think i m not the only with this proglem becouse the other that have post in this thread have the same my prob
If u want an example about the problem you can delete (with xnview) all the file in a dir with the DEL key and after select the folder emply and click again the DEL key and u see that don't work
Bye
Bye
My steps
• I tested as following :
1. Create a new sub-folder in a folder containing images, i.e.<Empty>.
- I did that in TC.
2. Start XnView >> Browser >> Main folder :
a. In the tree, the new empty folder is shown. Select it and press DEL, nothing happens.
b. In the board of thumb nails showing the main folder contents,
select the <Empty> sub-folder >> Press DEL, nothing happens.
• Like I said above, only the Delete entry on the local menus can delete that empty folder,
except from the board of thumb nails where it has no local menu…
- I performed the same test three times with the same result.
Xp-Pro SP1 here.
Re: My steps
I can't confirm, seems to be a problem with settings, please send me .ini?
otreus
