I had a system-crash with Windows 98SE and
had to install it all over (Delete all in c:\windows\)
Than I installed Delphi 7 again (after deleting all
files in \Delphi 7\ directory.
I then had in mind trying the delphi-project that comes
with GSF SDK for Delphi.
Before the crash, Icon could be read. Now however not
XnView can (after installing it too) read ico-files.
What is wrong?
Copying the dll-files into c:\windows or c:\windows\system
gave no solution to this problem.
The error-message: File not readable. Unknown format.
How to solve it?
Thanks
Jansen
can't read icon-files after reinstallation
Re: can't read icon-files after reinstallation
Are you sure that your icons are good?Philips10 wrote:I had a system-crash with Windows 98SE and
What is wrong?
How to solve it?
Philips10
