I don't know - a bug or my fault:
I take a PNG and convert it with Batch-Prozessing to TIF (1 bit, B/W, LZW).
http://img412.imageshack.us/img412/8199/gedrehtlt0.png
When I use the setting "Dither", I get a dithered TIF, which I don't want.
http://img254.imageshack.us/img254/6113 ... herza9.png
When I use "no dither", I get an empty image.
http://img412.imageshack.us/img412/6572 ... hercs9.png
Peter
PNG to B/W-TIF: Dither or nothing?
Peter2
rra
Drahken
It seems to be an issue with the formula for setting it to binary. It turns solid white regardless whether you use the export function to export it to b/w tiff, png, gif, bmp, etc, or if you set it to b/w (without dither) directly in xnview. The problem is with the pale shade of the lines. If you set the lines to a darker color (this can be done by setting it to 16 colors & then editting the colormap to change the pale blue to a darker color, or by setting it to greyscale & then cranking the contrast up & darkness down) & THEN convert to binary, it'll come out as you would expect it to.
Also, if you just crank the contrast up on the original pic, it will turn white when you reach 86%.
rra
