don't show the scroll bar at the bottom of the window explor
otreus
Post by otreus »
Hi:)
at the bottom of the window to explore resources i have a scroll bar that i don' tlike becouse every time that i drag a file into another dir, the scroll bar it moves and makes it difficult operation.
There is a way for don't show it o block the movement?
Many thank's :)
otreus
Post by otreus »
someone can answer me?
Layout ?
:arrow: otreus
:) Hello !
• Please, show an image about that you mean, I assume it's in the browser,
and if so, check which layout you are using.
:mrgreen: KR
otreus
Post by otreus »
thank's
i have post an image here
http://rapidshare.com/files/152078973/Immagine.GIF.html
the scrollbar that i mean is with a circle on it. I want disable it or have an option for block it when i drag an image from a folder to another one
but my english is so terrible that u haven't know my question? :( :( :(
SIMPLE !
:arrow: otreus
:) Again…
• The reply is on your picture below :
- Just move the separator (splitter) with the –| |– cursor you get on it…
:mrgreen: KR
otreus
Post by otreus »
u don't know the problem
i don't want resample the windows with the separator becouse i want see a big thumbail of the image
Tip, yes, miracle, no…
:arrow: otreus
• If you enlarge the tree area, that doesn't reduce the thumb nails size ! Simply, you'll get less thumb nails per rank.
• The width of the tree area (and other parts of the browser) is hard-coded, and can't be changed, AFAIK…
Supposing we have :
Hard coded Tree Width (for that layout) = 200 pixels (just an example), the scrolling-bar shall appear
as soon as the adjusted width is narrower, and disappear when the width is = or larger than the coded value…
- That's a Windows feature.
¤ Well, you can expect tips here, but not miracles ! Image
• You might try another layout : View menu >> Layout
:mrgreen: KR
otreus
Re: Tip, yes, miracle, no…
Post by otreus »
Clo wrote::arrow: otreus
Supposing we have :
:mrgreen: KR
You speak a little hard for my english :D
i like see 2 list of thumbnails 450x450 becouse don't like see little thumb.
If is impossible don't show the scrollbar i request if is possible that, when i drag a file, the scrollbar is automatic stopped, i think isn't so hard add this feature.
I think it is a very useful option for those who organize and move many files from one folder to another
Thank's for all :)
