Tool-bars missing icons (variant…)
:arrow: Pierre
:) Good evening,
• I've still issues with the icons of the tool-bars, another hitch is shown below :
• Three icons are missing suddenly in the start-up empty View, like indicated.
- This occurs randomly after n… starts, but when you get it then it remains as is.
- Renaming the <foo.bar>, XnView attempts to use a ghost <default.bar> which doesn't exist
instead of the one stated in the INI, like shown below :
     Image    Image
• Also :
- In the bar file, the syntax .\ to fill up the lack of a local variable in the icons paths
(separate *.ICO missing in the bitmap) no longer works always in the RC1 (it did in the ß…).
• Please, try to build a bar file with THE SAME SKIN and icons, and name it also <Medals.bar>,
I can't do more to guess that occurs in the tool-bars feature. :|
:mrgreen: KR
ckit
Post by ckit »
I can confirm most of everything here, it's why I walked out on XnView in the first place.
1.94.2 has similiar problems too.
Hell, I can't even get my files associated with XnView properly and we're at RC1?
ckit
Post by ckit »
Nevermind, ckv's file association manager works or at least the only bit of software around here that seems to.
Re: Tool-bars missing icons (variant…)
Clo wrote: • Three icons are missing suddenly in the start-up empty View, like indicated.
And if you use the foo.bar, do you have the problem too?
You would like that doens't change the name?
I don't understand, i have not changed toolbar feature since 1.94.2
You use ./ to use ico file in skins?
ckit wrote:Hell, I can't even get my files associated with XnView properly and we're at RC1?
The association doesn't work or you have not the icon? I've checked and the problem is UPX so it's not a good solution :-(
Lesmo16
Post by Lesmo16 »
Pierre, please try one of the following command line arguments for UPX:
--compress-icons=0
Don't compress any icons.
--compress-icons=1
Compress all but the first icon.
--compress-icons=2
Compress all icons which are not in the first icon directory. [DEFAULT]
Everyone who believes in telekinesis, raise my hand!
ckit
Post by ckit »
The association works but I had a generic icon for each image :(
Decompress the exe, and all will be good
RGBA
Post by RGBA »
Lesmo16 wrote:Pierre, please try one of the following command line arguments for UPX:
--compress-icons=0
This works as well. 8)
and might reduces the packing process without extra Aspack for a single file.
XnView 1.95.3 de | XP Prof. SP3
ckit
Post by ckit »
Ok I think I fixed mine...
1. Run "upx -d xnview.exe"
then
2. Run "upx -9 --compress-icons=0 xnview.exe"
I forgot how much fun you can have at the command line :)
bugmenot
Post by bugmenot »
resize image also has no image
*.ICO needed
:arrow: bugmenot
:) Hello !
• There is no "Resize" pattern in the main bitmap, so you must use an extra *.ICO file for that.
• You can draw one, or simply tell me which size you need and I'll do…
:mrgreen: KR
