Aspect Ratio Lock on Crop
Wickster
Post by Wickster »
New member here, sorry if my first post is a request, but I'm a new XNView user too and have been playing with most of the features for the past 2 days. :)
Anyway, I edit a lot of rendered images for animation and usually crop to the screen size for regular NTSC, PAL and HD.
Would it be possible to add an aspect-ratio lock when cropping? The usual cropping aspect ratio for me is 4:3 and 16:9. There are however other aspect ratio crops that can be added like generic photo sizes for portraits and landscapes.
Thanks in advance.
rra
Post by rra »
Hello Whickster,
what you want is already implemented:
use option edit/set selection ratio/
here you can choose between lots of standard ratio's
or even your own custum ratio.
However I don't know how to set this ratio as the
default value ??
René
Wickster
Post by Wickster »
Wow, I learn something new everyday...
Sorry for not noticing this, like I said i am very new to xnview.
Thank you René. :)
No default…
:arrow: rra
:arrow: Wickster
:) Hello !
• I guess that making the custom selection the default is not supported, AFAIK… :|
• A bit aside, you could see THAT PAGE
• A long while ago, I proposed something in the same painting in that TOMMY's THREAD with a (supported) mock-up…
:mrgreen: Kind regards,
