gflLoadBitmapFromHandle with Delphi
Philips10
Post by Philips10 »
Hi Pierre
Could you please give us Delphi-programmers a few lines of code that shows us how to use gflLoadBitmapFromHandle
I got
ms := tmmorystream.creat
try
image1.picture.bitmap.savetostream(ms);
e := gflLoadBitmapFromHandle( ?? , gfl_bmp, lp, fInfo);
finally
ms.free;
end;
If this is right so far, what to add for the two questionmarks ??
If not at all, please a few lines that shows the use of gflLoadBitmapFromHandle
Thanks and kind Regards
Jansen
Re: gflLoadBitmapFromHandle with Delphi
Philips10 wrote:Could you please give us Delphi-programmers a few lines of code that shows us how to use gflLoadBitmapFromHandle
I got
try
finally
ms.free;
end;
I don't know very well Delphi, perhaps someone who knows Delphi & C/C++ can help...
Andreas
Post by Andreas »
Here is a small example in Borland C++.
A conversion to Delphi should be easy.
//       CALLBACKS
GFL_UINT32 GFLAPI myReadFunction(GFL_HANDLE handle, void *buffer,
                                 GFL_UINT32 size)
    int ret = 0;
    TStream *s = (TStream *)handle;
    ret = s->Read(buffer, size);
    return ret;
GFL_UINT32 GFLAPI myTellFunction(GFL_HANDLE handle)
    return s->Position;
GFL_UINT32 GFLAPI mySeekFunction(GFL_HANDLE handle, GFL_INT32 offset,
                                 GFL_INT32 origin)
    Word soOrigin = 0;
    switch(origin)
        case SEEK_END:
            soOrigin = soFromEnd;
            break;
        case SEEK_CUR:
            soOrigin = soFromCurrent;
            break;
        case SEEK_SET:
        default:
            soOrigin = soFromBeginning;
            break;
    s->Seek(offset, soOrigin);
    return s->Position;
//        TestFunc
void __fastcall TForm1::Testfunc()
    GFL_LOAD_PARAMS lp;
    GFL_FILE_INFORMATION fi;
    GFL_BITMAP *gflbmp;
    GFL_ERROR error;
    TMemoryStream *ms = new TMemoryStream();
    Image1->Picture->Bitmap->SaveToStream(ms);
    gflGetDefaultLoadParams(&lp);
    lp.ColorModel = GFL_BGR;
    lp.LinePadding = 4;
    lp.Callbacks.Read = myReadFunction;
    lp.Callbacks.Tell = myTellFunction;
    lp.Callbacks.Seek = mySeekFunction;
    error = gflLoadBitmapFromHandle((GFL_HANDLE)ms, &gflbmp, &lp, &fi);
    gflFreeBitmap(gflbmp);
    delete ms;
Andreas
