Save/Load Search Result lists
roytam1
I think XnView should have ability for saving search result into a list file (maybe in m3u liked style will be great) and loading list file back to search result window, just like what Windows Vista do.
oops66
Re: Save/Load Search Result lists
Hello,roytam1 wrote:I think XnView should have ability for saving search result into a list file (maybe in m3u liked style will be great) and loading list file back to search result window, just like what Windows Vista do.
I support your suggestion (export or import function to or from a files list).
It's already possible, but quite difficult !
Tools\search\ ...your criteria ... search
Browse
Select all (or tag all, for information: tag is a kind of temporary category)
Create\file listing ... (then save the list)
To "load", you can create a new category, and put the result of your search into this category
roytam1
Yes it is possible but not user friendly enough.oops66 wrote:Hello,roytam1 wrote:I think XnView should have ability for saving search result into a list file (maybe in m3u liked style will be great) and loading list file back to search result window, just like what Windows Vista do.
Browse
