Does XnView open .att files?
Johny
Post by Johny »
hello.
One of my users has received a ".att" and asked for help on opening it. By searching on the net, I've been directed to this web site.
The said .ATT files has 78oc in size... so I'd tend to think it's some kind of mistake... but still; would XnView be linked to it ?
thank you...
Re: Does XnView open .att files?
Hello Johny,
Johny wrote:One of my users has received a ".att" and asked for help on opening it. By searching on the net, I've been directed to this web site.
You're right, here. XnView does support .att files, which is the "AT & T Group 4" format which is often used for facsimiles (faxes).
Not sure what 78oc means, if this is 78 Octets (Bytes), I doubt that you will see much. The file is either very well compressed or corrupted.
Greetings,
Helmut
