Batch Processing incorrectly parses some script files
TheEvilHammer
Post by TheEvilHammer »
Using the XnView GUI, I created a new batch processing script with the following transformations:
  • Resize
  • Add Text
  • Add Watermark
  • Resize
I saved the list of transformations as a script (.xbs file), which looks like this (actual settings removed):
resize( ... )
text( ... )
watermark( ...)
resize( ... )
settings( ... )
output_path( ... )
output( ... )
However, if I try to open this script in the Batch Processing dialog in XnView, the script file is not parsed correctly: the last transformation (the second resize) is missing from the list of transformations. Not surprisingly, if I run the batch processing task, the last resize operation is not performed.
Re: Batch Processing incorrectly parses some script files
With 1.95??
TheEvilHammer
XnView version 1.94.2
Could you try with 1.95? And send me the xbs?
TheEvilHammer
Yup, still a problem with 1.95. I will PM you the script file.
Ok, the problem is xbs save, add a space before ) for watermark
TheEvilHammer
Yup, that fixed it. Will this be fixed in the next version?
