1.95 - XnView very slow
Micha
today I installed 1.95 and I must see, that it need endless time to read directories full of images. I installed 1.93.6 again and anything is fine.
My OS is XP64. I don't have more infos.
Ciao,
Micha
Ciao,
Micha
Re: 1.95 - XnView very slow
Strange, do you use cache DB? Could you try without?Micha wrote: today I installed 1.95 and I must see, that it need endless time to read directories full of images. I installed 1.93.6 again and anything is fine.
Henri
I found same issue and found solution for me at least.
XNView came a lot faster after I deleted all caches with XNView tools-options-thumbnails-cache-remove all.
I changed also compression to be lossy, it was lossless.
Micha
Do you mean disable cache at the thumbnail options or an other option? Disable thumbnail cache dosn't help.xnview wrote:Strange, do you use cache DB? Could you try without?Micha wrote: today I installed 1.95 and I must see, that it need endless time to read directories full of images. I installed 1.93.6 again and anything is fine.
@Henri: I would like to keep the thumbnail cache, because many files are cached (approx. 2GB - some images are high res HDRIs)
Do you have tried to optimise the cache?
metallithrax
Do you have big difference if you disabled the cache between 1.94.2 & 1.95?metallithrax wrote:I am also having this problem
With a folder containing 442 sub folders and 12437 images, 1.94.2 opened the thumbnails in about 2 minutes. 1.95 has been running for about 5 minutes and still hasn't opened them.
They are already thumbnailed and cached.
Could you try to rename the .db file to test?
Very strange, could you send me your email by PM?
metallithrax
Vad
