"Show files in subfolders" cannot be disabled easily.
Perhaps not a bug, but in other programs (FreeCommander, Total Commander) it can be enabled and disabled with the same menu item (and shortcut), checkbox is shown if it's enabled, same as "[v] Tool Bar" in xnview.
There is a workaround Alt+Left, but it's not good, because also the path is changed. It might be quite frustrating for some users since Backspace and "up one level" button doesn't work. Escape will close xnview...
xnview 1.95, win vista.
Dreamer
