Deluxe Paint Animation .ANM format
StooieStooie
Post by StooieStooie »
I recently came accross some old animation files of mine that were created in Deluxe Paint Animation, which was a sister program to Deluxe Paint on the PC.
The only way I could view these was to convert them to single frames using an old command line convertor, (http://rtcm.thecomitatus.com/knowledge- ... /Dakit.zip)
I noticed the Zip file also contains the source code to the ANM file format. So would it be possible for a future version of XnView to support the playback of ANM files??
Thanks. :D
Re: Deluxe Paint Animation .ANM format
StooieStooie wrote:I recently came accross some old animation files of mine that were created in Deluxe Paint Animation, which was a sister program to Deluxe Paint on the PC.
Ok, i'll take a look at this format, do you have some examples of ANM?
StooieStooie
I'll mail you offlist with a couple of files...
Thanks in advance!
:D
Bildoo
Post by Bildoo »
I can make it to this time though :| :idea:
Jerzzey
