Batch rename with resetted counters per folder
ned.niederlaender
Post by ned.niederlaender »
I would like to see an option in batch renaming processes. It should be possible to reset the counters (###) per folder, if all files of subfolders are shown.
This way, it would be simple to rename whole folder branches using the folder names in the new file name (e.g. something like "<Folder name> ##"). Now, the counter does not reset at the next folder, but continues to increase the number.
Thanks,
Ned
Sxilderik
Post by Sxilderik »
I second that !
Utilisateur d'XnView depuis des lustres, client depuis juillet 07
JohnFredC
Post by JohnFredC »
Support++
John
