Sorting mode not saved
:arrow: Pierre
:) Hello !
• :bug: Changing the option in the "Sort by…" list works only during the current session,
it's always reset to "Name" in the next session… :(
• Important note :- I tested with a fresh new INI (made a backup copy of the current one and emptied the used one),
that doesn't change anything, the new sort order is lost.
:mrgreen: KR
Re: Sorting mode not saved
Which view mode do you use? Which sorting?
Extension only ?
:arrow: Pierre
:) Hello !
• It seems that only (?) “Extension” is not saved. Please, try the following steps, supposing you have “Name” (default) :
1. Change to “Extension”, close MP.
2. Restart it, check the sort order : “Name” is back !
3. Set i.e. “Date”, close :arrow: restart.
4. Check the sorting mode : “Date” is alright there.
5. Change to “Extension”, close :arrow: restart.
6. Check the sorting mode : “Date” is back !
• The direction doesn't matter, it has its own entry in the INI.
• I couldn't find out the value for Extension with the INI entry :
sort= ???
• This value is not written in the INI when one changes the sorting order to “Extension”…
:mrgreen: KR
Fixed up…
:arrow: Pierre
:) Hello !
• Seems fixed up in MP 0.12, Sort by extension is saved through the sessions now, TX !
:mrgreen: KR
