Nero Cover Designer File Not Viewing Correctly
RichieRich
Post by RichieRich »
Having designed a DVD cover using Nero Cover Designer (6.3.1), I was sad to find out that it cannot be saved in any other format but .NCD.
XnView was listed as one of the applications that can read those files but when I attempt to open it the cover is pixelated.
Any ideas?
Re: Nero Cover Designer File Not Viewing Correctly
RichieRich wrote:Having designed a DVD cover using Nero Cover Designer (6.3.1), I was sad to find out that it cannot be saved in any other format but .NCD.
Any ideas?
XnView only extract picture from .ncd file
forestred1
Nero CD Cover image
Post by forestred1 »
RichieRich - Did you solve the problem? I also designed a CD cover, saved it (.ncd) and emailed it to myself at another computer so I could print it on a high-quality printer. When I tried to open it with XnView, nothing happened, not even pixilated. Noth-ing.
Re: Nero CD Cover image
forestred1 wrote:RichieRich - Did you solve the problem? I also designed a CD cover, saved it (.ncd) and emailed it to myself at another computer so I could print it on a high-quality printer. When I tried to open it with XnView, nothing happened, not even pixilated. Noth-ing.
Could you send me it? perhaps you have not a thumbnail in it...
Mr Roboto
.ncd Files
Post by Mr Roboto »
I suffered the same Problems. Whats the problem about opening .ncd files?
