I'm trying to use nconvert to convert 16 bit (colour depth) TIFF format images into Maya IFF format images.
I am using the following options...
convert -v -n 1 10 1 -out tdi -o filename.####.iff filename.####.tif
This works but the IFF images are only have a colour depth of 8 bit, however the IFF format does support the 16 bit.
So I was wondering if there is a flag I'm missing to switch on 16 bit output to TDI/Maya IFF or whether nconvert does not support this output.
Thanks for your help,
Jeff
16 Bit Maya IFF support
Re: 16 Bit Maya IFF support
Currently nconvert convert 16=>8 bits, so i must build nconvert to support 16bits too
