1.95.x - XnView doesn't remember last folder
EmFeNo
Post by EmFeNo »
XnView 1.95 and 1.95.1 don't remember the last folder even if configured to do so under Tools ⇨ Options ⇨ General ⇨ Startup ⇨ Startup Directory, neither Last Used nor Current options work.
Tried this with clean installations of the Complete version.
Thanks for your hard work.
Re: 1.95.x - XnView doesn't remember last folder
I can't reproduce this bug
EmFeNo
Post by EmFeNo »
When I exit XnView leaving the browser at My images folder (which is relocated in D:\My documents\My images\) and then re-open it, the browser shows either the C:\Documents and Settings\Administrator\Desktop\ or C:\Documents and Settings\Administrator\ folder.
I'm using Windows XP 32-bit Home Edition SP3, if it helps.
EmFeNo wrote:When I exit XnView leaving the browser at My images folder (which is relocated in D:\My documents\My images\) and then re-open it, the browser shows either the C:\Documents and Settings\Administrator\Desktop\ or C:\Documents and Settings\Administrator\ folder.
Someone with this strange bug?
pic_viewer
Post by pic_viewer »
Not really. But if the browser is set to ' Files of owner/My Pictures' it will reopen at 'My Files/My Pictures'. But these are identical on my machine, so...
Alain Angouleme
Meme probleme.
Post by Alain Angouleme »
Même probleme.
Seule solution pour y rédier ne pas cocher effacer effacer les fichiers et repertoires a la sortie (dans le menu interface).
Cordialement.
klaus2
Post by klaus2 »
it's a bad side effect of the change of option "Purge 'Most recently used files and dirs' on exit"
See the discussion about this issue in:
http://newsgroup.xnview.com/viewtopic.php?t=16061
EmFeNo
Post by EmFeNo »
Yes, I activated that feature without suspecting it could cause a conflict with the other settings.
Thank you for your help!
