I tried to rename files from IPTC-Data to the format
YYYYMMDDhhmmss with template:
<IPTC:Created Date><IPTC:Created Time>
But, is not working.
Only Created Date is used.
How can i resolve my problem?
fohi
Batch rename name template with 'IPTC:Created Time'
fohi
Hmm, typically you can modify the date format using date format variables, e.g. <Date [Y-m-d_H-M-S]> would output "2008-10-29_21-31-33". (Available format variables are listed in the menu "Insert >> Date format variables > ...")
For some reason I don't know the date variables cannot be applied for the IPTC date. Probably a bug.
