printing exif info on the photo
Birsen
Post by Birsen »
i am a new user of xnview. Is there an option to print some of all exif info on the photo? That makes is a lot easier to discuss the photo whitin a group.
t.i.a.
Birsen
Peter2
Post by Peter2 »
Tools - Batch Processing - Tab "Transformation" - Image - Add text - Parameter >> - Select Exif Info - Select Position, Text font and size and color - Start ...
Peter
Post by Guest »
Great, that works. Thank you very much
