Support for bicubic resize?
sacharja
Bicupic resize is the standard of all picture viewers. Why does XnView not support it? It just shows the raw image after resizing without applying any post-processing filters.
- Forum Librarian
sacharja
- Forum Librarian
sacharja
Thought exactly the same. E.g. ACDSee calculates which part of the image is shown after the zoom and applies the filter just to this part. When the user moves the image it shows the unaltered image till the user let the mousebutton go (stops moving the picture) and applies the filter afterwards.Anonymous wrote:With "Enlarge" enabled, it makes zooming is considerably slower. Esp. if you enable change zoom in fixed steps.
Would zooming only the viewable parts of the image increase speed?
Windows XP SP2 / XnView 1.95.2
I would even go so far to call the current XnView behavior a bug because it will get exponentially slower the more is zoomed.
oops66
FYI: Yes it's a known problem
http://newsgroup.xnview.com/viewtopic.p ... sc&start=0
But the XnView MP version solves this issue !
sacharja
