Thumbnail generation for quite large images
PSHRutPark
Post by PSHRutPark »
Have generated a couple of large panoramic images of just over 1GB each. The original panorama TIFF files (as generated) have been saved as NEFs.
For some reason XnView wont generate thumbnails for these images, no matter what setting I select in the Thumbnail Options. (The preview images are displayed normally)
Equivalent images of less than 1GB generate thumbnails normally.
Is there a file size limit to thumbnail generation?
Thanks
PETER
Re: Thumbnail generation for quite large images
Do you have a size limit in option/File list?
Maxi reached
:arrow: Pierre
:) Hello !
PSHRutPark wrote
Have generated a couple of large panoramic images of just over 1GB each. …
• The maximal size (default) is 0.999999 GiB, and can't be increased (it should need a digit more).
- Hence the PSHRutPark's big files are bigger than this limit…
:mrgreen: KR
PSHRutPark
xnview wrote:Do you have a size limit in option/File list?
Thanks Pierre. I forgot about the presence of this option.
Added another digit to the max size and now it works.
PETER
