Menu icon for "Browse with XnView"
Crysler
Post by Crysler »
I often use the Shell-Extension (Right-Click > Browse with XnView).
Unfortunately on my system that menu is cluttered with a lot of items so "Browse with XnView" is hard to find.
Would it be possible to add an icon left to the menu item?
Dreamer
Post by Dreamer »
I'm using a file manager icon toolbar (drag & drop) instead of this way, but it's a good idea.
+1
BTW Have you tried the Shell extension (thumbnail)? It's very easy to find it with this. :wink:
Dreamer
Crysler
Post by Crysler »
If this is irony and I'm not getting it I'm sorry, but what do you mean by "trying the shell extension"?
Apart from the "Browse with XnView" functionality there's no functionality regarding folders I know of. The Shell Extension displays for image files and I use it a lot but I was referring to what displays when you right-click on a folder.
Dreamer
Post by Dreamer »
No, sorry, I meant "Use Shell Extension" option, but you are right, it's unavailable for the folders - but - perhaps it would be a nice option, display 4 thumbnails if there are images inside the folder.
Dreamer
Crysler
Post by Crysler »
I think we are still talking of different things.
My concern is just having an icon in the context menu:
ckv
Post by ckv »
Browse with XnView context menu is not actually a shell-extension, it's a simple shell shortcut menu and this his kind of menu item doesn't support icons.
Writing a new shell-extension would be reguired to get the icon on that menu item.
Dreamer
Post by Dreamer »
Crysler, I know exactly what you mean (that was just a suggestion) but it looks it's not possible.
Dreamer
Crysler
Post by Crysler »
Ok, thank you ckv and Dreamer, now I understood the problem.
