everytime I want to start Version 1.95.3 from my USB stick the program asks for many dll's (beginning with ncs...dll).
What is the problem?
Not able to start 1.95.3
Re: Not aible to start 1.95.3
Remove the Xecw.dll
jis
Hi Pierre, I am sorry, but I don't understand your recommendation.xnview wrote:Remove the Xecw.dll
I am upgrading XnView every time by hand from XnView-win-full.zip. I noticed that XnView-win-full.zip version 1.95.3 doesn't contain these files in PlugIns folder when I compare it with previous version 1.95.2:
awdvstub.exe
IlmImf.dll
NCScnet.dll
NCSEcw.dll
NCSEcwC.dll
NCSUtil.dll
Xawd.dll
Xbsb.dll
Xdjvu.dll
Nordlicht2001 has a problem with missing NCS*.dll files, you recommend to remove even one more file, the Xecw.dll. Please Pierre, can you explain the reason behind?
I use the latest XnView version in the Windows 8.1 Pro with Media Center.
I've removed from zip package ECW & EXR plugin
jis
