XnView 1.95.n command line print auto page orientation
sunhill
Post by sunhill »
Hello Pierre,
we use the parameter -print to send tiff drawings (1bit, G4fax) directly from another application across XnView to the printer.
Since the chance to V1.9.5.n, the pages are not more automatically rotated if needed.
So pictures in landscape orientation will printed in half size centered on a portrait page.
In the Version 1.94.n we had no problems with this issue.
I would appreciate if you could have a look at this behaviour.
Regards
Sunhill
