is it possible to "loop backwards" when browsing i
veggen
Post by veggen »
I know it is possible to start from the beginning when you press next on the last image in the folder, but is it possible to jump to the last image if you press previous on the first?
Hope you guys understand me...
If you want to "wrap" from the first image to the last and vice versa, please activate setting:
Tools > Options | View | Misc | Loop on the file list
I hope I understood right...
veggen
Post by veggen »
Thanks for the speedy reply! Yes, you got me perfectly.
I've just noticed that the option you've mentioned is already enabled but sometimes wrapping backwards (with Backspace) still doesn't work. But sometimes it does. With PageUp and PageDown it always works...
veggen wrote:Thanks for the speedy reply! Yes, you got me perfectly.
Good to hear. :-)
veggen wrote:I've just noticed that the option you've mentioned is already enabled but sometimes wrapping backwards (with Backspace) still doesn't work. But sometimes it does. With PageUp and PageDown it always works...
Hmm, currently "Backspace" key is for "Up one folder level" , so I'd be surprised if "Backspace" did any wrapping at all.
Post by Guest »
Thanks for clearing it up. I can't really remember how I managed to get Backspace to wrap, but it doesn't really matter.
Thanks again.
