Is this possible? If not, then let this be a feature request
How to edit the small toolbar
thany
I mean the toolbar in browse mode, that sits above the listview. Basically I'm only interesed in the directory combobox, But I can't seem to find out how to edit it, or at least move the combobox to the very left.
NOOOpe !
• Sorry, you can't, the icons shown there are patterns of a single bitmap, please glance HERE
• However, you could draw a bitmap -according to the instructions of the Manual- with neutral patterns (
your BG colour or "transparent") for functions you don't need. But you can't move the location of these patterns.
• However, you can hide the tool-bars totally (both the small and large ones) from the View Menu (untick the entries).
thany
No---
• Not at all… If you draw neutral icons, that doesn't shorten the bitmap.
- And if you HIDE the small tool-bar from the menu like I said above, the history drop-down list is hidden too,
an oddness the Author might explain (I never hid it before, so I couln't notice that)…
