Ctrl+A in the IPTC Caption text area
dandv
Post by dandv »
I often want to select the entire Caption from the "Edit IPTC data" dialog, but right now I have to press Home, Shift+End. Ctrl+A would be great.
HTH,
Dan Dascalescu
+1
Ctrl+A is (more or less) standard for "Select all". For multi-line edittexts in dialogs "Ctr+A" should select all the text in the edittext. If possible, this should work for all (multi-line) edittexts.
