image distorts after resizing
mimsford
Post by mimsford »
I hope someone can help. I've used XNView successfully for a couple of years (version 1.82.4) but recently have encountered problems with jpg. images being severely distorted after I resize them. (They look fine until I save them, close them and reopen them.) This typically happens when I'm resizing photos uploaded from my Canon digital camera.
I am using Canon's ZoomBrowser EX to actually upload the files, then trying to edit them in XNView because I prefer its functionality.
Thanks so much for any assistance.
Re: image distorts after resizing
Could you send me a sample?
mimsford
sample?
Post by mimsford »
did you get a sample from me? If not, please tell me the best way to send or attach? Thanks.
Re: sample?
mimsford wrote:did you get a sample from me? If not, please tell me the best way to send or attach? Thanks.
You have send me it on my email? (@xnview.com)?
Re: sample?
Which value do you have in option/read-write/write/Jpeg quality??
mimsford
distorted image
Post by mimsford »
Ah, it was on "lowest," in an attempt to reduce the file size ...
I believe that solved my problem.
