after I installed XnView Shell extension ( v2.5 ), everything work ok. When I shut down / restart windows, XnView Shell extension preview no longer appear on my menu when I right click.
after restarting win xp several times to find the same problem, I uninstalled and reinstalled it and then it work ok again. But when I restart windows, the same problem appear again.
any ideas why?
Thanks.
no XnView Shell extension preview after shutdown
Re: no XnView Shell extension preview after shutdown
xnview/Option/system integration/Use xnview shell extension is greyed?
it's not greyed. It's ticked.xnview wrote:xnview/Option/system integration/Use xnview shell extension is greyed?
right now, the preview option appear sometimes only.
and when I left click on the preview pic, nothing happen.
Only sometimes??? Which format of picture?Anonymous wrote:it's not greyed. It's ticked.xnview wrote:xnview/Option/system integration/Use xnview shell extension is greyed?
XnViewShell folder is in XnView folder?and when I left click on the preview pic, nothing happen.
