I have recently switched to XnView from ACDSee 3. (yeah, I know, took me long enough.)
One feature I really liked about ACDSee is that you could hit spacebar to advance to the next image in the folder. When you reached the last image and hit spacebar, it would take you back to the beginning. However, with XnView, that doesn't happen. Is there an option anywhere in the program to turn that feature on? I have looked everywhere I can think of to look, but cannot find it.
Thanks.
Question re: using spacebar to view next image
Options are for…
• Go to :
Options (F12) >> General >> Keyboard / Mouse >> Space [Go to next Picture]
- Then, use the Back-space key to come back to the previous one…
- To read as a loop :
Options >> View >> Misc. tab >> [×] Loop on the file-list
klaus2
somehow related ... i'm using this setting ...
but sometimes it happens that occasionally i press space bar in the browser (thumbnail view)
and - arghh- the "show tag box" option will get active
so that i need to navigate thru the menu to revert that.
So, is it possible to cut that link between space bar in the thumbnail view and "show tag box" ?
klaus2
klaus2
Dreamer
Why, just press the space again.klaus2 wrote:somehow related ... i'm using this setting ...
Dreamer
klaus2
Dreamer
klaus2
Dreamer
firehorse
Re:
Within the browser/thumbnail view, I could use space bar to select and move onto the next picture. With this feature I could quickly select a bunch of pictures, right arrow to skip a good one, if I made a mistake I could go back and press space bar to select/deselect a picture. And then when I wanted to, I could just press delete and the program would delete the ones I have selected.
Currently in Xnview you press space bar to select/tag the current picture but it does not move onto the next picture, thus doubling the required key presses.
I would like the option to "tag/untag and go to next item" with the space bar.
Another great feature of Compupic pro was persistent tagging. When I closed the program down and opened it up next time, all the tagging/selection was still there.
Thanks
Alan
I was a user of Compupic pro. One feature I have never found on other programs even Xnview is exactly this.Dreamer wrote:Option for Space also in browser would help, perhaps:
- tag/untag
- select/unselect (same as ctrl+click)
- no action
and (for me) also:
- tag/untag and go to next item
Thanks
Alan
oops66
Re: Re:
Hello, +1 why not, I support (with the space shortcut or any other key (already customizable into Options\...)firehorse wrote:...I would like the option to "tag/untag and go to next item" with the space bar...
... a persistent tagging or some albums collection names ... maybe/probably into a next XnViewMP version ......Another great feature of Compupic pro was persistent tagging...
http://newsgroup.xnview.com/viewtopic.p ... 81#p112481
