I have problems to understand which printer is used a default-printer for XnView:
Version 1.92.1, January 2008:
Neither the "Windows default printer" nor the "last used printer" is used. It is one of the printer list where I can see no logic behind it?
Version 1.95, 14.10.2008:
The "Windows default printer" is used?
Question 1:
Are my observations correct?
Question 2:
Is it possible to set a default printer for XnView (in both versions named above)?
Thanks
Peter
Which printer is used as default printer?
Peter2
Re: Which printer is used as default printer?
There is a problem in version 1.92/93/94 to select default printer
Peter2
Peter2
Strangexnview wrote:YesPeter2 wrote:And 1.95: is the "Xnview default" always identicaly with "Windows default"?
- I use 1.95.3 de from October 2008 and get the Windows default printer.
- A colleague uses 1.95.3 de from Nov. 2008 (downloaded today) and allways gets the same "NOT default printer". Aftre deinstalling the not-default XnView uses the default; after reinstalling the not-default XnView uses again the same not-default ...
Peter
??? There is only one 1.95.3 (5 nov), perhaps you use 1.95.1??Peter2 wrote: Strange
- A colleague uses 1.95.3 de from Nov. 2008 (downloaded today) and allways gets the same "NOT default printer". Aftre deinstalling the not-default XnView uses the default; after reinstalling the not-default XnView uses again the same not-default ...![]()
Peter2
Peter2
