[Possible bug] XnView.db path save violaton
stisev1
Post by stisev1 »
Hello all,
Great program but I've experienced one problem
XnView.db does NOT save within the XNView directory. Yes, I've made all of the appropriate setting changes, searched, googled, etc.
It still saves: C:\Documents and Settings\STi Sev\Application Data\XnView\Xnview.db
instead of
D:\Applications\XnView
I am puzzled as to why it's doing this
Changing UseFileDB=1 (to UseFileDB=0) does not change anything. Any ideas?
Here is my settings file (I use INI, not registry)
[AutoCrop]
Tolerance=0
[Browser]
ActionConvert=0
ActionSlide=1
ArrangeBy=7
AutoCollapse=0
AutoPlay=0
BColorFilter01=jpeg, 237 237 202
BColorFilter02=gif, 220 235 220
BColorFilter03=png, 232 222 220
BColorFilter04=bmp, 227 227 255
BColorFilter05=tiff, 192 197 235
BColorFilter06=tga, 230 255 255
BColorFilter07=iff, 247 235 235
BColorFilter08=sgi, 247 237 242
BColorFilter09=pcx, 235 230 230
BColorFilter10=psd, 255 255 227
BColorFilter11=pcd, 235 215 235
BColorFilter12=psp, 237 208 163
BColorFilter13=pict, 202 202 255
BColorFilter14=xpm, 242 227 21
BColorFilter15=xbm, 216 216 216
BColorFilter16=pbm, 191 191 182
BColorFilter17=pgm, 207 207 197
BColorFilter18=ppm, 235 225 159
BColorFilter19=ras, 255 255 227
BColorFilter20=wmf, 187 187 187
BColorFilter21=emf, 212 212 212
BColorFilter22=ico, 217 247 227
BColorFilter23=cur, 217 247 227
BColorFilter24=ani, 217 247 227
BColorFilter25=fpx, 229 255 255
BColorFilter26=jp2, 237 237 202
BackListColor=16777215
BackgroundColor=16777215
BorderColor=0
BorderSize=0
CRAW=1
ClickRename=1
Custom0=<Focal>mm f/<F> <Exposure>s <ISO>iso
Custom1=<Width>x<Height> - <Size>
Custom2=
Custom3=
Custom4=
EnableAutoRefresh=1
FilterBy=5
FitVideo=0
FitWindowOption=1
FlatStyle=0
FollowLink=0
FullPreview=0
FullRowSelect=1
Height=584
HidePreviewScrollBar=0
HighQuality=0
IconHeight=69
IconInfo=2039
IconWidth=92
InfoO-0=1
InfoO-1=1
InfoO-10=1
InfoO-11=1
InfoO-12=1
InfoO-13=1
InfoO-14=1
InfoO-2=1
InfoO-3=1
InfoO-4=1
InfoO-5=1
InfoO-6=1
InfoO-7=1
InfoO-8=1
InfoO-9=1
LabelsAlignment=1
LabelsSpacing=1
Layout=3
ListHeight=256
ListViewHeight=553
ListViewWidth=754
ListWidth=188
NavigateSubFolder=0
OldTreeTab=0
OldValue=0
OneClick=1
OpenAction0=0
OpenAction1=1
OpenAction2=1
OpenAction3=1
OpenAction4=1
OpenAction5=1
OpenAction6=1
PasteOnSubfolder=0
PreviewColor=8421504
PreviewHeight=74
PreviewWidth=0
PrintInfo=0
RecognizeByExt=1
RenameHideExtension=0
RotationKeepData=1
RotationUseEXIF=0
RotationUseLossless=1
ScanHeaders=0
SelectLastAddedFiles=0
SharpenThumb=0
SharpenValue=50
ShowDesktop=0
ShowDirList=1
ShowFilename=1
ShowGridLines=1
ShowHexaView=0
ShowHiddenFile=0
ShowPreview=1
ShowSmallToolbar=1
ShowTabTree=1
ShowTabView=1
ShowToolTips=1
Spacing=4
StartupDirectory=
StartupIn=1
StatusInfo=0
SyncWithView=1
TabTreeLabel=0
TagSetting=1
TextBackColor=12632256
TextColor=0
Thumb41Folder=1
ThumbConfig=10 5 50
ThumbGamma=1.00
ThumbnailColor=16777215
TimerForPreview=200
TooltipText=<Filename>, <Size> bytes, <Modified>||<Format>||<Width>x<Height>, <BPP> bits
TreeViewHeight=473
TreeViewWidth=200
TxtExt=txt c c++ cc h cpp pas js css php ini
UpdateTreeViewWhenRefresh=1
UseBackgroundColor=0
UseBytes=0
UseColor=1
UseFileDB=1
UseGammaOnThumb=0
UseInch=0
UseRating=1
UseRenameDlg=1
UseShadow=1
UseTag=0
UseThumbnailColor=0
VHidePanel=1
VListLayout=0
VideoFrame=0
VideoPlayBar=1
ViewColumn=127
Viewas=1
Width=968
X=0
Y=0
column0=213
column1=72
column10=0
column2=120
column3=240
column4=104
column5=384
column6=384
column7=48
column8=0
column9=0
tcolumn0=0
tcolumn1=0
tcolumn2=0
tcolumn3=0
[Cache]
Compression=1
IsActive=1
MaxDir=99
SavingMode=0
[Canvas]
KeepRatio=1
Position=4
[Capture]
Area=0
ClientArea=0
Delay=5
Directory=
FormatName=jpeg
HideCursor=1
HideXnView=1
HotKey=9
IncludeCursor=0
Method=0
Multiple=0
SaveIntoFile=0
[ContactSheet]
Columns=4
Flags=4
FontBold=0
FontHeight=-13
FontItalic=0
FontName=Courier
FootNote=
HeadNote=
Height=1000
MarginHeight=16
MarginWidth=16
Rows=4
SpacingHeight=8
SpacingWidth=8
Text=<Filename>
TextBackgroundColor=16777215
TextColor=0
ThumbnailBackgroundColor=12632256
Width=1000
[Convert]
CloseDlg=1
DefaultFormat=jpeg
DeleteOriginal=0
HideError=0
KeepFormat=0
KeepOriginalDate=0
KeepSubFolder=0
Overwrite=1
UseOrgPath=0
[File]
ConfirmFileDelete=0
CopyCompanionFile=1
CopyTo=
DeleteRecycleBin=1
DirName_0=
DirName_1=
DirName_2=
DirName_3=
DirName_4=
DirName_5=
DirName_6=
DirName_7=
DirName_8=
DirName_9=
KeepDate=0
MoveTo=
PasteNoCopy=0
[FileSelector]
IncludeSubDirectories=0
[Full]
BackColor=0
DualMStretch=0
DualMUse=1
Fit=2
HidePlayBar=0
HideScrollBar=1
SizeDelay=2048
UseDelay=1
[Fullscreen]
FontBold=0
FontCharSet=1
FontHeight=-13
FontItalic=0
FontName=Courier
IsTransparent=1
Position=0
TextBackColor=0
TextColor=16777215
[Install]
ViewAsName=0
[Iptc]
Combine=0
KeepDate=1
Leave=1
Merge=1
Replace=0
UpdateXMP=1
[Load]
CRAWAutoBalance=0
CRAWBlueScaling=1.00
CRAWBrightness=0.80
CRAWCameraAutoBright=1
CRAWCameraBalance=1
CRAWGamma=0.60
CRAWHighResolution=0
CRAWRedScaling=1.00
ChannelOrder=0
ChannelType=1
DjVuMaxDpi=0
EXIFDpi=0
EXIFRotate=1
ExrGamma=1.00
GrobBpp=0
HdrGamma=1.00
Height=256
ICCProfile=0
ICCProfileName=
IcoIn32bits=1
IgnoreError=0
Lut10to8Name=
Offset=0
PcdBase=2
PddPage=0
PngComposeWithAlpha=0
PngComposeWithTransparency=0
PostscriptDpi=72
PostscriptPageSize=0
Preview=1
UseEmbeddedThumbnail=1
UseLut=0
UseOrgIfSmall=0
WMFHighResolution=0
Width=256
YuvHeight=576
YuvOffset=0
YuvWidth=720
[OpenWith]
OpenWith_0=
[Player]
SoundOn=1
Volume=100
[Plugins]
0=Xbmf.dll|294|bmf|BMF|bmf;
1=Xcompound.dll|308|max|3DS Max thumbnail|max;
10=Xjng.dll|293|mng2|Multiple Network Graphics|mng;
11=Xjp2.dll|805|jp2|JPEG-2000 JP2 File Format|jp2;j2k;jpx;jpf;
12=Xjp2.dll|805|jpc|JPEG-2000 Code Stream|jpc;
13=Xjpegls.dll|294|jls|JPEG-LS|jls;
14=XMrSid.dll|308|sid|MrSid|sid;
15=Xp2.dll|295|p2|Pic2|p2;
16=Xpax.dll|294|pax|PAX|pax;
17=Xpwc.dll|295|pwc|Fast Piecewise-constant|pwc;
18=Xsff.dll|293|sff|Structured Fax Format|sff;
19=Xwhypic.dll|294|ypc|Whypic|ypc;
2=Xcompound.dll|308|mic|Microsoft Image Composer|mic;
20=Xwic.dll|806|wic|J Wavelet Image Codec|wic;
21=Xwlm.dll|806|wlm|CompW|wlm;
22=Xwmp.dll|294|wmp|WMP|wdp;hdp;
23=Xawd.dll|276|awd|AWD|awd;
24=Xbsb.dll|262|kap|BSB/KAP|kap;
25=Xdjvu.dll|276|djvu|DjVu|djvu;djv;iw4;
26=Xecw.dll|775|ecw|Enhanced Compressed Wavelet|ecw;
3=Xcompound.dll|308|mix|Picture It!|mix;
4=Xeri.dll|295|eri|ERI-chan (Entis Rasterized Image)|eri;
5=Xfif.dll|295|fif|FIF (Iterated System)|fif;
6=Xfpx.dll|820|fpx|FlashPix Format|fpx;
7=Xiwc.dll|805|iwc|WaveL|iwc;
8=Xjbig.dll|804|jbig|JBIG|jbg;bie;jbig;
9=Xjng.dll|293|jng|Jpeg Network Graphics|jng;
Nb=27
[Print]
AllPages=0
AutoRotate=0
BottomMargin=0.20
CType=0
Columns=4
EFontBold=0
EFontHeight=10
EFontItalic=0
EFontName=Courier
ETextColor=0
FText=Page <Page>/<Page>
FontBold=0
FontHeight=10
FontItalic=0
FontName=Arial
Gamma=1.00
HText=
Height=10.00
HoriSpacing=1.00
KeepRatio=1
LeftMargin=0.20
Multiple=0
Option=0
Position=4
RightMargin=0.20
Rows=4
Text=
TextColor=0
TextPosition=0
TopMargin=0.20
Units=0
UseFooter=1
UseHeader=0
VertSpacing=1.00
WFontBold=0
WFontHeight=10
WFontItalic=0
WFontName=Courier
WFontOrientation=0
WOrientation=0
WText=
WTextColor=0
WTextPosition=0
WUse=0
Width=10.00
XScale=2.00
YScale=2.00
[Process]
AutoView=0
Deinterlace=0
FilterAutoView=0
LastValue_0=-255
LastValue_1=-255
LastValue_10=-255
LastValue_11=-255
LastValue_12=-255
LastValue_13=-255
LastValue_14=-255
LastValue_15=-255
LastValue_16=-255
LastValue_17=-255
LastValue_18=-255
LastValue_19=-255
LastValue_2=-255
LastValue_20=-255
LastValue_21=-255
LastValue_22=-255
LastValue_23=-255
LastValue_24=-255
LastValue_25=-255
LastValue_26=-255
LastValue_27=-255
LastValue_28=-255
LastValue_29=-255
LastValue_3=-255
LastValue_30=-255
LastValue_31=-255
LastValue_32=-255
LastValue_33=-255
LastValue_34=-255
LastValue_35=-255
LastValue_36=-255
LastValue_37=-255
LastValue_38=-255
LastValue_39=-255
LastValue_4=-255
LastValue_40=-255
LastValue_41=-255
LastValue_42=-255
LastValue_43=-255
LastValue_44=-255
LastValue_5=-255
LastValue_6=-255
LastValue_7=-255
LastValue_8=-255
LastValue_9=-255
ShowPreview=1
[Rename]
Replace=
Template0=
Template1=
Template2=
Template3=
Template4=
Template5=
Template6=
Template7=
Template8=
Template9=
With=
[Resize]
DpiUnit=0
KeepDocSize=0
KeepRatio=1
PrintUnit=1
Resample=7
Unit=1
[Save]
AddExtensionIfNotExist=1
BmpCompress=0
ChannelOrder=0
ChannelType=1
DefaultFormat=jpeg
DpxIn10Bits=0
DpxMSBF=0
EcwTargetRatio=20
FpxQuality=100
Gif87aHeader=0
GifInterlaced=0
GifTransparentIndex=0
GifUseTransparentIndex=0
Hp49Header=0
IffCompress=0
IwcQuality=100
Jpeg2000FileSize=100
Jpeg2000Mode=1
Jpeg2000Quality=80
Jpeg2000Ratio=10
JpegDCTMethod=0
JpegKeepEXIF=1
JpegKeepIPTC=1
JpegKeepXMP=0
JpegProgressive=0
JpegQuality=80
JpegRebuildThumb=1
JpegSmoothFactor=0
JpegSubSampling=0
KeepOrgDate=0
LdfAddThumbnail=1
LdfQuality=1
LdfjpmBackFactors=1
LdfjpmBitonalCoder=2
LdfjpmForeFactors=1
LdfjpmQuality=8
Lut8to10Name=
LwfCompression=0
LwfJp2Compression=0
LwfJp2Rate=10
LwfJp2Size=4096
LwfMode=0
LwfQuality=70
LwfRate=10
LwfSize=1024
Offset=0
OptimizeHuffmanTable=0
Os2Header=0
PcxCompress=0
PdfCompress=4
PdfJpegQuality=80
PngCompressionLevel=6
PngInterlaced=0
PngTransparentIndex=0
PngUseTransparentIndex=0
PpmAscii=0
RgbCompress=1
SoftCompress=1
TgaCompress=0
Tiff1Strip=0
TiffBinaryCompress=0
TiffCompress=0
UseLut=0
UseOrgJPEGQuality=0
WMPQuality=100
WicQuality=100
WlmFactor=1
[Scr]
PlayMode=0
WindowHeight=480
WindowWidth=640
[Slide]
AudioLoop=0
BackgroundColor=0
Center=1
EffectFlag=1
EffectMask=268435455
FitSmall=0
FitSmallVideo=0
FontBold=0
FontCharSet=1
FontHeight=-13
FontItalic=0
FontName=Courier
Frame=1
Full=1
HighQuality=1
IsTransparent=1
Loop=1
MouseNav=0
NoError=0
NoTitle=1
OnTop=0
PlayMode=0
Position=0
Random=0
SLDRelativePathname=0
ShowText=1
SortOder=0
SortOrder=0
SoundFilename=
Text=<Directory><Filename>
TextBackColor=0
TextColor=16777215
Timer=5.00
UseGammaInEXE=1
UseSound=0
UseTimer=1
WinHeight=480
WinWidth=640
[Start]
AllFormats=1
AlwaysOnTop=0
BStatusBar=1
BToolBar=1
BarFilename=
CColor-0=0
CColor-1=0
CColor-10=0
CColor-11=0
CColor-12=0
CColor-13=0
CColor-14=0
CColor-15=0
CColor-2=0
CColor-3=0
CColor-4=0
CColor-5=0
CColor-6=0
CColor-7=0
CColor-8=0
CColor-9=0
CheckUpdate=2
Custom1Extensions=HTM HTML MHT MHTML XML XHTML EML NWS URL
Custom2Extensions=
CustomIniPathFolder=D:\Applications\XnView
DirName_0=
DirName_1=
DirName_2=
DirName_3=
DirName_4=
DirName_5=
DirName_6=
DirName_7=
DirName_8=
DirName_9=
ENTER=1
FileName_0=
FileName_1=
FileName_2=
FileName_3=
FileName_4=
FileName_5=
FileName_6=
FileName_7=
FileName_8=
FileName_9=
Filter0=1
Filter1=1
Filter2=0
Filter3=1
FlatButtonInToolbar=1
Height=679
InFullscreen=0
LMB=1
Language=en
LastCheck=20440418
LaunchBrowserAtStartup=1
MMB=0
MaxFilesize0=999999
MaxFilesize1=999999
Maxi=0
MaximizeXnviewAtStartup=0
MenuUseExit=0
Only1ESC=1
OnlyOneInstance=0
OpenAll=1
ParamsSavingMode=1
PathAvi=
PathBrowse=D:\Applications\XnView\
PathCache=
PathConvertSave=
PathLoad=
PathPalette=
PathSave=
PathScript=
PathSlide=
PathSlideScript=
PurgeMostRecentlyUsed=1
SaveAsUseNewName=1
SavePosition=1
SavedFileType=:gif:jpeg:png:tiff:bmp:emf:pcx:jp2:
SavingMode=1
SelectedShowAgain=0
ShowAgain=268435415
ShowSaveDlg=0
ShowTextInToolbar=0
ShowToolTipsInToolbar=1
TabBar=1
TabBarCfg=3
TabBarDefault=1
TabBarMaxChar=32
TagShowFlags=0
ToolbarBrowserConfig=-1
ToolbarBrowserConfigHigh=-1
ToolbarName=Phoenity 2
ToolbarViewConfig=-1
ToolbarViewConfigHigh=-1
UseDifferentPosition=0
UseExtendedMenu=1
UseMostRecentlyUsedFiles=0
UseNewMRUF=0
UseSameAsOrg=0
VStatusBar=1
VToolBar=1
Version=195
ViewHeight=679
ViewMaxi=0
ViewWidth=968
ViewX=552
ViewY=69
Width=968
X=417
Y=155
[View]
AppFitToImage=1
BackColor=0
BackgroundColor=0
CRAW=2
CacheBehind=1
ColorInfo=0
CopyClipboard=0
DeleteGoNext=1
DirKeyFlag=1
DirKeyVFlag=2
DisableGifAnimation=0
EnableBmpAnimation=0
Fit=1
Gamma=1.00
GridColor=255
GridSize=2
GridSpacingX=80
GridSpacingY=80
GridType=1
HideScrollBar=0
HighZoomQuality=1
IgnoreAlpha=0
ImageLoop=0
KeepGridForNextPrevious=0
LeftButtonFlag=1
LockZoom=0
MouseNavigation=1
NoMultipleView=1
OneViewMultiple=0
OnlyOneView=1
OpenHexaViewIfNotPicture=0
PlayMovie=0
PlaySound=0
ReadAhead=1
ResetXY=0
RightButtonFlag=1
ScrollVal=10
ShowColorInfo=0
ShowText=1
SlideDelay=1000
SlideDirection=0
SlideLoop=1
SpaceKeyFlag=1
StatusInfo=1
Text=<Comment>
UnitsSize=0
UseAlpha=1
UseBgImg=0
UseDPIRatio=1
UseGamma=0
UseTranspIndex=1
UseUndo=1
UseZoomStep=0
UserSelHeight=0
UserSelRatioX=0
UserSelRatioY=0
UserSelWidth=0
UserSelXdpi=0
UserSelYdpi=0
VideoFitAll=0
VideoLoop=0
VideoPlayBar=1
WheelMouseFlag=0
ZoomStep=10
stisev1
IGNORE!
Post by stisev1 »
Oh Jeez,
PLEASE ignore this thread. It was a stupid (yet advanced) mistake with involving Sandboxie and OpenPIPE. The setting was being forcibly reset by Sandboxie.
Sorry again for cluttering the forum. Once removing it from Sandboxie, Xnview worked fine.
There is no bug/problem. Ignore!
