Make settings in general once for all on a Terminalserver
kriegera
Post by kriegera »
i have some questions about XNView configuration.
We want to install XNView on our Terminalserver but only as a Fax Viewer.
So I am testing the Software on a Testserver.
We want to have that every user on the Terminal Server automatically opens .tif and .tiff files in XNView but other files with e. g. MSPaint.
How can I make these settings once that it is for all who log on to the server.
We want also to know if it is possible to make the same with settings like Menubar Style and so on.
Is there a possibility to do it?
Thanks
Re: Make settings in general once for all on a Terminalserve
You can change the .tif registry entry
kriegera
Post by kriegera »
first of all:
Thanks for fast reply.
So theres a Problem:
You think of the HK_Classes_Root\.tif key I suppose but I tried to do this without any result.
I made the changes to my user when I logged on to the server and then I exported the registry key.
Can you please tell me the exact way to change registry keys and what registry key that the changes are for all users on this server?
If in user session, you use option/Association, it works?
kriegera
Post by kriegera »
Sry,
but I don't know exactly what you mean.
In a user session, start xnview, in option/association, click for example on TIF. And check if it's ok in windows explorer?
kriegera
Post by kriegera »
ahh Okay.
Sry ;-)
I did it in an user Session and in this session id works correctly. Then I exported the Reg Key (explained in my 1. post) and tried to import it for all but without success.
The registry export file doesn't work for another user??
Could you post the content?
kriegera
Post by kriegera »
so i made the settings again and exported the registry again.
Here you are:
.tif Regkey
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.tif]
"Content Type"="image/jpeg"
"PerceivedType"="image"
@="jpegfile"
"Progid"="XnView.tif"
[HKEY_CLASSES_ROOT\.tif\OpenWithList]
"a"="xnview.exe"
"MRUList"="cab"
"b"="shimgvw.dll"
"c"="mspaint.exe"
[HKEY_CLASSES_ROOT\.tif\OpenWithProgids]
"TIFImage.Document"=hex(0):
"MSPaper.Document"=hex(0):
"ACDSee 8.0.tif"=hex(0):
"ft000001"=hex(0):
"jpegfile"=hex(0):
[HKEY_CLASSES_ROOT\.tif\PersistentHandler]
@="{098f2470-bae0-11cd-b579-08002b30bfeb}"
[HKEY_CLASSES_ROOT\.tif\XnView.bak]
@="ACDSee 8.0.tif"
.tiff regkey
[HKEY_CLASSES_ROOT\.tiff]
"Content Type"="image/tiff"
@="TIFImage.Document"
[HKEY_CLASSES_ROOT\.tiff\OpenWithProgids]
[HKEY_CLASSES_ROOT\.tiff\PersistentHandler]
I hope this will help to find the problem.
Thanks
kriegera wrote:.tif Regkey
@="jpegfile"
  1. The value for "Content Type" needs to be changed from "image/jpeg" to "image/tiff".
  2. The value for @ needs to be changed from "jpegfile" to "XnView.tif".
kriegera, could you please post the registry keys of [HKEY_CLASSES_ROOT\TIFImage.Document] & [HKEY_CLASSES_ROOT\XnView.tif]?
kriegera
Post by kriegera »
HiHo XnTriq,
I thought that something with .tif key isn't okay but I wasn't sure.
Okay I will change the settings and try.
By the way here are the two keys you wanted:
"EditFlags"=dword:00010000
"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\
  00,6f,00,6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,\
  32,00,5c,00,73,00,68,00,69,00,6d,00,67,00,76,00,77,00,2e,00,64,00,6c,00,6c,\
  00,2c,00,2d,00,33,00,30,00,36,00,00,00
"ImageOptionFlags"=dword:00000000
[HKEY_CLASSES_ROOT\TIFImage.Document\DefaultIcon]
@="shimgvw.dll,4"
[HKEY_CLASSES_ROOT\TIFImage.Document\shell]
[HKEY_CLASSES_ROOT\TIFImage.Document\shell\open]
"MuiVerb"="@shimgvw.dll,-550"
[HKEY_CLASSES_ROOT\TIFImage.Document\shell\open\command]
@="rundll32.exe C:\\WINDOWS\\system32\\shimgvw.dll,ImageView_Fullscreen %1"
[HKEY_CLASSES_ROOT\TIFImage.Document\shell\open\DropTarget]
"Clsid"="{E84FDA7C-1D6A-45F6-B725-CB260C236066}"
[HKEY_CLASSES_ROOT\TIFImage.Document\shell\printto]
[HKEY_CLASSES_ROOT\TIFImage.Document\shell\printto\command]
@="rundll32.exe C:\\WINDOWS\\system32\\shimgvw.dll,ImageView_PrintTo /pt \"%1\" \"%2\" \"%3\" \"%4\""
@="TIF Bild"
[HKEY_CLASSES_ROOT\XnView.tif\DefaultIcon]
@="C:\\Programme\\XnView\\xnview.exe,10"
[HKEY_CLASSES_ROOT\XnView.tif\shell]
[HKEY_CLASSES_ROOT\XnView.tif\shell\open]
[HKEY_CLASSES_ROOT\XnView.tif\shell\open\command]
@="\"C:\\Programme\\XnView\\xnview.exe\" \"%1\""
THX a lot
Greetz kriegera
kriegera
Post by kriegera »
Hi @ all.
I made the changes and it seems to work.
@="jpegfile"
Very Good... :D :D
But theres another thing I want to change for all.
This thing is to change the menu so that every user has the same Icons on the same position in the menu.
How does this work?
Do you make the changes also in the registry :?:
Thanks for your answers
kriegera wrote: This thing is to change the menu so that every user has the same Icons on the same position in the menu.
Sorry i don't understand
kriegera
Post by kriegera »
so in XNView you can change the position and number of menu icons.
You can change these settings here in the Options:
And I want to create one MenuBar for all users on the terminalserver.
For example:
Every user has the Icon for:
  • - Print
  • - Open
  • - Save
  • - Turn Left
  • - Turn Right
But these users aren't allowed to see the icon for:
  • - Settings
  • - Rectangle
  • - Help
I want to change these settings once so that every user has the same
MenuBar Settings similar to the setting that .tif files should be opened with XNView for every user.
Greetz & THX
kriegera
Sorry you can't edit menu bar
