Format of file could not be determined.
Post by Guest »
I have noticed since version 1.95.x that whenever you use the slideshow feature to view movie files that a dialog pops up with the follwoing error:
Warning:
Format of the file <I> could not
be determined.
The mpeg file seems to be playing in the background, but because of the warning, no further movie files can be viewed after pressing OK or CANCEL.
My fix has been to revert back to version 1.94.2
Have Fun !!
Shane
Re: Format of file could not be determined.
Strange, you have the 1.95.3? Only with mpeg?
Post by Guest »
xnview wrote:Strange, you have the 1.95.3? Only with mpeg?
Yes, I'm using 1.95.3 and have tried 1.95.0,1,2.
I think this is now being covered in another ticket. namely:
http://newsgroup.xnview.com/viewtopic.php?t=16143
Thanks
Shane
