<Moderator's note: This topic has been moved>
Is it possible to View and save pictures in random order?
thank you,
AL
Viewing & Saving pictures in random order.
AFAIK only using quick slide show - Options > View > Misc. > Direction > Random, or slide show - Ctrl+L > Use random order and then save as .sld, or .exe...
There are few requests to view pictures in random order:
Random Viewing / Transition Effects hotkeys
Use Space key to... "6 in 1" option
Dreamer
