have some problems figuring out the communicaton protocall
some one from QLD, Australia suggested that I uncheck "XnView Shell Extension" but i can't find such a title in the options list.
I use the run feature for download and insatlling: during instulation there is an error trying to replace existing file : error code 5.
my operating system is windows xp home service pack 3
thanks: keith
install 1.95.3 over 1.95.2 problem
keith
retired person
PM and search
• I sent you a PM but it seems you missed it…
• You can't replace the ShellExt DLL without renaming the old one prior…
- I explained that already recently to a user, maybe with the Search… ?
- The option you are talking of is not directly in the list but on the System Integration page…
- Forum Librarian
keith wrote:some one from QLD, Australia suggested that I uncheck "XnView Shell Extension" but i can't find such a title in the options list.
Clo ([url=http://newsgroup.xnview.com/viewtopic.php?p=68183#68183]Installation Error on Windows XP SP3[/url]) wrote:1. Ensure you that XnView is not running,
2. Rename <XnViewShellExt> as <XnViewShellExt> for instance.
3. Copy the new <XnViewShellExt> into its sub-folder …\ShellEx\*.* from the ZIP archive.
- Because some mysterious oddness of Win, you can't delete the "old" file on the spot.
- The old library'll be used till you reboot the PC, then the new one will be,
and you can delete the old one without any problem…
Vanished characters !
• In my text you quote, the extensions have vanished, so it's incomprehensible.
- It might be :
• Point noted…1. Ensure you that XnView is not running,
2. Rename <XnViewShellExt.dll> as <XnViewShellExt.dll.old> for instance.
3. Copy the new <XnViewShellExt.dll> into its sub-folder …\ShellEx\*.* from the ZIP archive.
- Forum Librarian
Re: Vanished characters !
Sorry, Clo! phpBB ate the file extensions, because stupid me forgot to tick the checkbox to “Disable HTML in this post”.Clo wrote:In my text you quote, the extensions have vanished, so it's incomprehensible.
