Import clipboard
nick_white
Import clipboard
Post by nick_white »
If I capture the screen with "Prt Scr" button, then want to paste in XnView, I don't have the "Import clipboard" option unless I open a browser or a file. I deactivated the browser from loading at start-up, so I have to open the browser, wait for the thumbnails to load, then use the "Import clipboard" feature.
It would be nice to have options like "Import clipboard" available from the XnView main interface, since some don't require any open files (or folders - browser).
In Basic mode (no window opened), you can use File > Import clipboard. (Right, it's a bit embarrassing to find the menu item there).
Button-Button…
:arrow: nick_white
:) Hello ! Welcome aboard !
• I use Alt+PrintScreen a lot, so I have set an Import Clipboard button in the tool-bars, in View modes
(start-up and with a file) and in the browser (more rarely used)…
- Now, that pattern is included in the new skins (default and mine), so no problem to add the button. :wink:
:mrgreen: Kind regards,
