Too slowly read a Sony RAW File
GimaPei
Post by GimaPei »
1. version 1.95.3
Usually, when read Sony RAW file, is fairly slow. 10 ultimatums take
By the way, RAW file opens fast if open attribute window at this next time first once.
Certainly, I do not know is what bug is unfamiliar but I should like to be ameliorated.
rra
Post by rra »
Yes this has already been adressed by me some time ago,
see:
http://newsgroup.xnview.com/viewtopic.p ... light=sony
I don't know if Pierre is working on a fix for this ??
René
Re: Too slowly read a Sony RAW File
You can use the embedded jpeg to speedup
rra
Post by rra »
Pierre,
I don't know what you mean with embedded JPEG,
is there a JPEG embedded in the raw Sony ARW file ,
and if so, how can I retreive this JPEG ?
regards,
René
option/View/Misc/Camera raw
GimaPei
I try your answer but it's not work
Post by GimaPei »
I try pirrer's answer but it's not work and
1.91.4 version is correctly work for Sony RAW file
any other version is not work
it looks like main core bug
rra
Post by rra »
This option doesn't seem to work,
I even ain't sure whether the ARW file does contain a
JPG thumbnail file, anyway if it does it isn't likely to be
a high-res. JPG image which I was hoping to view,
so the problem still exists.
Maybe in you will find some time to look at this problem.
Thanks anyhow,
René
Could you send me a sample? It was quicker in an old version???
rra
Post by rra »
No , as far as I know , reading the ARW type has always been very slow,
also the clarity is different (too light)
as compared with Photoshop CS2.
Here is a sample:
http://members.home.nl/ramekers/_DSC0561.ARW
René
GimaPei
It's fast version for Sony Raw file
Post by GimaPei »
ok it's fast version for sony raw file
download at : http://withbible.org/~gimapei/xnview.zip
Re: It's fast version for Sony Raw file
GimaPei wrote:ok it's fast version for sony raw file
You means that in 1.91 it's fast and not in 1.95??
GimaPei
Post by GimaPei »
I operate normally in only 1.91 versions.
It is speed problem when read Sony RAW file that I wish to speak
The normal speed is seen in affixing only 1.91 versions.
It is other bur all all turtle level.
have a nice day. and sorry my short english
