xnview v1.95.4: Switching off the tab bar
Karl02
Post by Karl02 »
Switching off the tab bar is not intuitive in my opinion, because there are several options at different places.
I tried the following:
- Options -> View -> View: check "Only one window view opened"
Then:
- Options -> Interface -> Interface: "Hide tab bar when only one window is opened"
However, usually there is always a browser tab, and when opening an image, there are two tabs, and the tab bar appears again.
After searching for a long time in the options dialog, I found the menu entry "View -> Tabs", which I unchecked, and then the tab bar was finally switched off.
Therefore I think that there should (also) be an option "Display tab bar" in Options -> Interface.
Furthermore, there is an option View -> View -> "No multiple view for same file". This option makes only sense if multiple views are activated. So the following structure would be reasonable:
[ ] Open multiple views
    [ ] Open only one view for the same file
-- Karl
