v0.12 Win32 (minor): Tree Pane->Vertical tabs wording
JohnFredC
Post by JohnFredC »
Open a browser tab.
1. Select #2 (for instance)
2. Show the tree pane
3. Toggle View->Tree Pane->Vertical tabs
Xnview only moves the tabs to the bottom or top of the folder pane, never to the side (ie. never vertical in Layout 2).
Same thing happens in Layout 5, for instance.
That menu command should probably just cycle the folder tabs position to all four borders of the tree panel, in sequence.
Also, a simple rewording of the menu item to "Position" (instead of "Vertical") would suffice to match all layouts and positions.
John
Re: v0.12 Win32 (minor): Tree Pane->Vertical tabs wording
Ok, right, it's an error in layout #2 & #5
