I use Czech MS Windows 2000 with CP-1250 as default charset and XnView 1.95.4 as default image viewer. So I add into JPGs file IPTC field (e.g. Caption) any Czech text and save. In XnView 1.95.4 is the typed caption text displayed correctly unlike in XnViewMP 0.12. I think XNViewMP expected UTF-8 so all the Czech chars upon basic ASCII are poorly displayed.
Note: Similar bug appears in XnView for Windows when I use the option "Update or create XMP" from present IPTC field text.
0.12: Wrong IPTC text encoding displayed
Re: 0.12: Wrong IPTC text encoding displayed
Right MP use UTF-8, so perhaps an option to choose the charset???Jarda wrote:I use Czech MS Windows 2000 with CP-1250 as default charset and XnView 1.95.4 as default image viewer. So I add into JPGs file IPTC field (e.g. Caption) any Czech text and save. In XnView 1.95.4 is the typed caption text displayed correctly unlike in XnViewMP 0.12. I think XNViewMP expected UTF-8 so all the Czech chars upon basic ASCII are poorly displayed.
Jarda
The option to choose the charset would be great (ideal) solution (not only in XnView MP but in "classic" XnView for creating XMP from IPTC field also)!xnview wrote:Right MP use UTF-8, so perhaps an option to choose the charset???Jarda wrote:I use Czech MS Windows 2000 with CP-1250 as default charset and XnView 1.95.4 as default image viewer. So I add into JPGs file IPTC field (e.g. Caption) any Czech text and save. In XnView 1.95.4 is the typed caption text displayed correctly unlike in XnViewMP 0.12. I think XNViewMP expected UTF-8 so all the Czech chars upon basic ASCII are poorly displayed.
Sorry i'm wrong, XnViewMP use local charset so perhaps a problem in 0.12
Jarda
Strange... Not all Czech chars are broken but please take a look here:xnview wrote:Sorry i'm wrong, XnViewMP use local charset so perhaps a problem in 0.12
http://www.asmodeus.info/text/testarea/ ... ew1954.png
(correctly displayed IPTC caption field text in XnView 1.95.4)
http://www.asmodeus.info/text/testarea/ ... viewmp.png
(IPTC caption text displayed incorrectly in XnView MP 0.12)
Ok, in the tooltips, but in the iptc panel, encoding is correct?Jarda wrote:Strange... Not all Czech chars are broken but please take a look here:xnview wrote:Sorry i'm wrong, XnViewMP use local charset so perhaps a problem in 0.12
Jarda
In the panel is displayed in the same way as in tooltip.xnview wrote:Ok, in the tooltips, but in the iptc panel, encoding is correct?Jarda wrote:Strange... Not all Czech chars are broken but please take a look here:xnview wrote:Sorry i'm wrong, XnViewMP use local charset so perhaps a problem in 0.12
Could you contact me by email?Jarda wrote:In the panel is displayed in the same way as in tooltip.xnview wrote:Ok, in the tooltips, but in the iptc panel, encoding is correct?Jarda wrote: Strange... Not all Czech chars are broken but please take a look here:
Jarda
Ok, You have new mail with screenshotxnview wrote: Could you contact me by email?
