How to resample
plamark
How to resample
Post by plamark »
Is there a way to resample an image to a higher or lower DPI? I know you can change the size of the image, but can you also change the resolution?
Thank you for your SDK. It's very nice.
Mark
Re: How to resample
plamark wrote:Is there a way to resample an image to a higher or lower DPI? I know you can change the size of the image, but can you also change the resolution?
Yes, you can access to Xdpi/yDpi of GFL_BITMAP
