How to add text?
JackInman
How to add text?
I'm a new dumb user and simply adding text through the menu is not clear how to make it happen... I want to add it, then size it and position it, but how do I do that.. the help is no help.
Re: How to add text?
You have Edit/Add text
For adding text, you
1 - use menu "Image > Add Text...".
2 - In the "Add text to image" dialog enter your text and set font size, font color, and so on as desired.
3 - Confirm the dialog with "OK"
4 - Move the mouse cursor to the position for adding the text.
5 - Add the text by left clicking.
Done.
Done.
Dreamer
