Attached image has corruption at bottom when loaded in GFL
Defenestration
Post by Defenestration »
The attached GIF image loads OK in GFL, but there is a whitish line running horizontally across the bottom (it should be orange). There is no white line when loaded in XnView (or when viewed in Firefox).
Using GFL SDK 2.90 64-bit unicode library.
Defenestration
Hmmm, after changing a bit of code, this seems to have fixed itself. :mrgreen:
Some of the changes involved changing some of the load params, so I'll see if I can work out which one(s) caused the problem.
