Syntax for -page num and Pdf file
Little mouse
Post by Little mouse »
Hello
I try to extract one page in a Pdf file with
nconvert.exe -out jpeg -page 7 -o tst.jpg guide.pdf
I get the fisrt page
with the -xall it's ok
The same syntax with a Pps file it's ok
Thanks a lot
Re: Syntax for -page num and Pdf file
-page 7 works only if you use -xall, right?
Little mouse
Sorry I was too short,
When I use :
nconvert.exe -out jpeg -xall -o tst.jpg guide.pps
It's ok I get tst-0.jpg tst-1.jpg tst-2.jpg ...
nconvert.exe -out jpeg -page 7 -o tst.jpg guide.pps
When I use :
nconvert.exe -out jpeg -xall -o tst.jpg guide.pdf
The problem is going :
I try the same syntax as the pps file
It doesn't much matter the number of the chosen page, it's always the first page which is generated in the file destination = tst.jpg
I try to put -xall before or after -page x, it's the same.
Is it more clear ?
Thanks a lot.
Right i confirm
Little mouse
Thank you for your prompt answer.
Do you think resolve this problem later?
Have a good day - LM
Little mouse wrote:Thank you for your prompt answer.
Yes, will be fixed in next release
